Castle Creations policy?
JeffEmbracedDC
JeffEmbracedDC's Avatar
Castle Creations policy? - 09.13.2008, 03:40 AM
What's Castle Creations policy on when their factory defective components cause failure of other components?
For example: If my MMM fries and takes out my $140.00 JR9100T and $85.00 Nomadio tranceiver?
Or.. if my CCBEC burns out and does the same thing?
Luckily I have not had this happen to me.. but to be confident in continuing use of such products it's something that would be good to know.
-Jeff
BL 8ight, BL FT B44, BL FT TC4, BL FT T4
  Send a message via Yahoo to JeffEmbracedDC Send a message via AIM to JeffEmbracedDC Send a message via MSN to JeffEmbracedDC
George16
Supermaxx
George16's Avatar
09.13.2008, 04:09 AM
There are some guys that experienced what you just described. I wondered if CC replaced their servos too.
I highly doubt they will.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
DRIFT_BUGGY
DRIFT_BUGGY's Avatar
09.13.2008, 05:50 AM
I haven't heard of anyone getting there parts replaced that was cause by ESC/BEC
Losi 8ight
MMM V1 w/1.20
Airtronics MX3 2.4Ghz
TP 5S 5000mah
Neu 2.5D/F
GT35R
09.13.2008, 05:56 AM
I just chucked some 8$ HC metal servos in there to get going (perfect fit for Traxxas).
Probably should just use cheap gear for testing the MMM as I see no hope that they
would be able to warrant/prove other parts affected by that SoB.
Electric Eel
09.13.2008, 06:52 AM
They don't replace components. I had a CCBEC fail and deliver full voltage to all my parts in a heli. 3 $100 servos, a $90 RX and a $350 gyro burnt. No refund except for the BEC. I sold it and bought another brand.
GT35R
09.13.2008, 09:28 AM
Ouch!
Now thats enough to make you really mad.
Especially when its only $20 item thats faulty.
asheck
09.13.2008, 11:00 AM
I just got my 2 replacements bec's.When they failed they took about 200 in servos with them. I got no reimbursment,but they did replace my mm for free even though I was running it on 4s when it went. I found some good deals on ebay for my replacement servo's and am really up in the air about whether or not to run the new bec. I mean a 30$ servo is nothing to lose sleep over , but if it failed again and left my vehicle servo less I could end up getting upset. They also told me to run 1 with the MMM that I got replaced also,so that really leaves me wondering, I mean what are the chances that they will both go out again and leave me monster truckless? Probably to high these days.
George16
Supermaxx
George16's Avatar
09.13.2008, 11:14 AM
Asheck, when CC told you to run the MMM with a BEC, did they tell you to do the mods, cut the red wire or leave everything intact on the MMM?
Revo with OS .18TZ
asheck
09.13.2008, 11:20 AM
Actually what they said was ,with the bec I had a slimmer chance of failure.Then you would just unplug the red wire.No other mods were discussed.I'm sure they would not tell me to go home and do mods that could/should be handled already.
JThiessen
JThiessen's Avatar
09.13.2008, 12:11 PM
Anytime you deal with aftermarket parts, you MUST proceed with the knowledge that you are your own warranty provider. For quite some time, I have been "hot rodding" my trucks, and I frequent the applicable forums that deal with Dodge diesel pickups. You wont believe the number of people that put aftermarket injectors or a chip in their truck, and when a piston melts, or a turbo shreds, they want someone else to cover the cost of replacement parts (beit Dodge or the manufacture of the aftermarket parts). Yes, if your particular item malfunctions, the manufacture should cover the item itself, but not the remainder of your vehicle.
09.13.2008, 03:00 PM
Logical, but still a shitty deal really.
Where's Brian and his over-voltage protection device he was designing when you need him...
JeffEmbracedDC
09.13.2008, 03:21 PM
What about using 2 BECs in series? Maybe set the first one to 6.5v and the 2nd one to 6.0v.
Any thoughts?
-Jeff
09.13.2008, 03:29 PM
...Where's Brian and his over-voltage protection device he was designing when you need him...
I was just thinking about that the other day when I was cleaning my workbench and moving my experiment breadboarding box. My little bro came over for vacation (from Maine where I used to live) so no time for that this weekend. And then, I am currently in a fairly large home renovation project (ripping out and installing carpet, painting, cleaning, etc since the parasite (ex) moved out) so time is a valuable commodity in short supply. If I get some time next week at work, I'll throw together a schematic someone can try out if they want. But actually breadboarding the circuit will have to wait. Until then, good luck with your BECs!
phatmonk
RC carbon junkie
phatmonk's Avatar
09.13.2008, 11:14 PM
My 3rd MMM v1 killed my spectrum synthisized receiver when it went poof
Sammus
Sammus's Avatar
09.13.2008, 11:27 PM
Any thoughts?
-Jeff
i wonder how that would go...
