Why dont you charge them and find out? Or I guess the first charge you wouldn't be able to tell. You could set your LVC higher than normal (say 3.2 or 3.3v) that should prevent the lower one (if there is one) from over discharging, then you can see if its significantly different voltage to the good one at the end of a run...
