VXL TACO
Owner of MaxxOrange
VXL TACO's Avatar
09.15.2008, 07:58 PM
Ok thanks, also why with one lipo plugged in the mamba max does not engage but the servos turn just fine? The settings on the mamba max? I have it set at 12v cutoff because I am running two 2s 4500 mah lipos, so with one 2s it probably cuts it off immediately.
" Any problem caused with a tank can be solved with a tank" - Peter Griffin
  Send a message via AIM to VXL TACO
