What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
09.18.2008, 01:37 AM
Dunno if it would cause this, but isn't there a minimum voltage rating on the MMM? Like 3S (11.1) or 10V?
Edit: With those 25C 2200 packs you should run them in parallel for use in a MT. One pack is only good for 55A (610W) continuous. If you only run one pack I think it would get pretty warm. If not, worse.
bruce750i
bruce750i's Avatar
09.18.2008, 04:55 PM
You can run them w/o the lipo sack, just set your cut off voltage at 3.2v a cell. 3s for 11.1v with a cut off of 9.6v or 6s for 22.2v with a cut off of 19.2v. But really they are a little small. I've ran two 1800 3s in parallel (3s2p=11.1v) in my rustler, but they acted a little undersized for my setup. What motor do you have on it? IDK either about the minimum voltage.
myndseye
myndseye's Avatar
09.18.2008, 06:09 PM
If my reciever is not putting out a neutral signal (as in it's not on), my Castle controllers will not initialize. They will give you the first few tones, and maybe count cells, but won't do the final ready to go tones. The fan will keep running until the controller finishes initialization.
