Go Back   RC-Monster Forums > Support Forums > Novak
lutach
lutach's Avatar
09.21.2008, 08:50 PM
Originally Posted by rchippie View Post
what wires do you mean ?. What gear ratio & spur would you suggest for the 13.5 ?.
The copper windings. See if there's any signs of burns. You were geared for 37mph and if it was me I would've started at 30/72 and taken from there, but I don't know how big your track is so all I'm doing is given you a starting point to check temps after you race a full 5 minutes. Your motor might've had something else go wrong that caused it to heat up like you said.
rchippie
rchippie's Avatar
09.21.2008, 09:00 PM
the wires look a nice & even shinny red in color . This track had a straight approximently 140 - 150 feet long . This motor had the none sinterd rotor . I think i will just but the upgraded rotor for this motor .
REAL MEN RUN BRUSHLESS
lutach
lutach's Avatar
09.21.2008, 09:13 PM
Yes, just get the rotors and see how it goes. I was also under the impression the wires were supposed to have a yellowish color as most high temperature magnet wires have it. I've had wires turn that shinny red color after they had heat issues and went bad.
rchippie
rchippie's Avatar
09.21.2008, 09:27 PM
Im not sure what color they are supposed to be . I dont want to buy a rotor if the can it's self is bad . I do know that when i picked up the car & the motor had no load on it there was no stutter in the motor . I dont know if that means anything .
lutach
lutach's Avatar
09.21.2008, 09:29 PM
I'll go open a couple of motors right now to see what color the copper wires are supposed to be. Give me a few minutes.
rchippie
rchippie's Avatar
09.21.2008, 09:35 PM
thank's are they novak motors ?.
lutach
lutach's Avatar
09.21.2008, 09:38 PM
Go ahead and buy the rotor. All the Novaks I have checked uses the red colored copper wires. You just demagnetized your rotor as you stated it didn't cog like they usually do.
