lutach
lutach's Avatar
09.25.2008, 07:57 AM
Originally Posted by Happywing View Post
So far, no luck. I can't get the connector off the board. The heatsink is in such good contact with the connector that I can't get it hot enough. the heatsink just sucks away the heat. I've about had it with this controller. Who's found a better alternative?
Man, I'm not even going to run mine then until something can be done. I think this is proof right here from our Monsters that one of the problems are caused by the heat touching the motor or power plugs.
