09.25.2008, 10:40 AM
How's this? Photoshop isn't working so I had to use paint. Excuse it lookig horrible.
You have to much time on your hands... But that is funny!
09.25.2008, 10:42 AM
Haha, thanks. Not much to do when you're home sick...
JThiessen
JThiessen's Avatar
09.25.2008, 11:04 AM
When you are done with this, I'll send you a couple of my trashed out Revo bulks to see if you can get them to work in that.
09.25.2008, 11:52 AM
Please do, I do have a few revos, but no spare bulks at the moment. I have a feeling that the bulks would need some work to fit the lst case, but still cheaper to sell someone modded bulks than a hybrid style diff case. Not necessarily as good as the hybrids, but cheaper. More options are always good.
09.25.2008, 03:43 PM
Pimp my Emaxx....
A purpose built adaptor would encourage more people to go this route; the guys who I've suggested the LST2/Muggy diffs to were scared away... buy having to find a little bit of plastic and trim it in half (oh-so difficult ). This would be as good as UE Ultralites pretty much, only much much cheaper.
09.25.2008, 03:56 PM
Pimp my Emaxx....
Basically identical to the UE setup... You would really like my setup, nice snug fit and lines everything up perfectly...
09.25.2008, 04:04 PM
Showoff!!
09.25.2008, 04:08 PM
Indeed, shame I already have the UE/Hotbodies diffs, otherwise I'd be interested for certain.
09.25.2008, 04:49 PM
You could always build another maxx...
jayjay283
jayjay283's Avatar
09.26.2008, 11:40 PM
Yeah but the lst/muggy etc diffs only have 4 spider gears. I have some of those heavy duty cups for them, same cups for 8 & 8T, (Ill send one with your traxxas center diff) to check out, Its alot nicer than the stock cups.
09.27.2008, 01:58 AM
Thanks Jay, I will have to check out the heavy duty cup. Would make a good alternative for the rear diff, as that one seems to take more abuse than the front.
I just finished up the bpp torpedo chassis and used a plastic case std diff in the front, and a al case std diff in the back. Both are shimmed properly, and it seems like a nice setup. The std lst gear sets are lower ratio than the maxx so a larger pinion will be required. I figured that I would try the "weakest" lst diff setup in this truck and see how they do.
09.27.2008, 10:04 AM
What setup are you planning? I can see lutach's ESC, kind of hard to miss.
09.27.2008, 12:10 PM
8s lipo, via a pair of 4s 3700 fp packs. Aveox 36/38/2 motor (1100kv or so). I also have a mega motor that would work nicely that I may try out. I need to pick out some tires out of the collection, but am leaning towards a set of 40 series wheels with bowties...
I have a hitec 5997 servo and will run spektrum via the m8...
09.27.2008, 12:12 PM
What's the rotor length of the aveox?
09.27.2008, 12:27 PM
It is identical to a 1515 2y. All of aveox motors are y winds. And the numbers represent the outside dimensions of the can, where the neu specs are the rotor... Same construction in both motors.
