bdebde
That's All Folks!
bdebde's Avatar
10.05.2008, 07:42 PM
If you are using motor brakes in a truggy, you will need heavier diff fluid in the center diff to get decent brakes (i find 30k to be minimum). Also, I had problems with a big maxximum on older mgm controller as well. Be sure to try higher switching frequency on the mgm (new ones have this option), as that is one of the reasons they (plett) recommend the shultzes.
