TexasSP
Something, anything, nothing
TexasSP's Avatar
10.06.2008, 05:45 PM
They are the same people who buy $200 worth of nimhs and a mega1 timed charger... Lipo is cheaper IMO to nimhs. Less weight, better performance, and longer pack life. If you buy matched nimhs and a decent charger it is the same cost as lipos and a charger. A balancer will add a bit of cost, but a lipo should give about 100 cycles min, and a really good nimh pack may do half that before it has a serious capacity reduction...
So factor a $80 6 cell matched 4200-4600mah nimh, a $130 ICE, $60 power supply, and then a second $80 nimh wen the first has worn out... $350
Or a $120 trakpower 4900 2s lipo, $130 ICE charger, $60 power supply, and a $40 balancer... $350
No contest...
Preaching to the choir Brother pimp......
I would rather have a cheap set of lipo packs than a high end set of nimh any day.
So, the short answer to this thread is:
Can it be done? Yes.
Should it be done? No. Not unless you want to risk overcharging high cells.
You just made the rest of this thread pointless with that post.
www.cubicle101.com
