10.11.2008, 05:14 PM
Stick with 5 or 6s. I have found that my 4500 30c 6s lipos are close to maxed out with the hacker 11xl. I am not sure if the 1521 will draw less amps, really do not think it will. I would stick with the 4900 5s pack and a lower kv motor.
Byte
10.12.2008, 04:39 AM
Ok, what about 2x3s? NEU Energy 4900mAh 3s 25-50C? And a NEU 1521 with 1900Kv?
That would be good I think?
10.12.2008, 07:44 AM
Step down to the 1521 1y and you should be fine, just gear it for the speed you want. The motor has so much torque there is no need to rev it any higher.
10.12.2008, 12:34 PM
Sounds like a great conversion. If you don't have the dough for the 1521, check out the Mega 22/45/2 for 6s.
Byte
10.12.2008, 05:49 PM
Ok, thank you for all your advises Lincpimp! Thanks for all the great help! Now I just need to get the money ok, I have it, but I want to work for the money. So next month or something I will buy the motor. 1 month later the LiPo's, and finally the ESC.
All other guys also thank you for helping me!
Just a little list:
- Losi LST2
- NEU 1521 1Y
- NEU Energy 25-50C 2x3S 4900mAh
- Mamba Monster Max
- RC-Monster 2 Speed pinion adapter 5mm bore
- Self made motor mount
- Self made Battery tray
Again: Thank you for helping me!
EDIT: Another thing, I forgot the name for connecting those 2 LiPo's together. Something like: ...-Kabel
I want one with Deans, does somebody know one here on rc-monster?
