Originally Posted by ffactory666
Luciano were do you get the Novak HV 1.5 and 2.5 from ?
I have looked but cannot find any , lowest i got was 3.5 . Did you go with the Novak HV because it has a 5mm shaft .
I found the Tekin in 2.5 but don't know if it has the 5mm shaft . I'm thinking the 5mm shaft would be of benefit to a speed run car .
The Novak HV1.5 and HV2.5 were custom request. The normal HV is from 4.5 up to 7.5 I believe. Yes I got because of the 5mm shaft and the longer motor would make a little more torque to push my car better. All the other smaller motors only go down to 2.5 and comes with 3.2mm shafts and those have a Kv of around 11,000-13,000 depending on the diameter of the magnet. I just added a test dummy in my TC3 now. I found a good deal on a Orion Vortex 2.5T, so things should get going Saturday at English Town.
