10.19.2008, 12:13 AM
Originally Posted by speedracer1129 View Post
Heath,
If you are shooting for 65+mph speeds, do not use the Phaltlines!! I tested out a pair of brand new ones this past Wednesday. I have a Losi 8T setup for high spped runs. We clocked the car at 75, but the tires blew off!! The tires were checked and reglued before the run still they lasted about 6 passes or so. I have heard that IMEX is coming out with some MT foams for 17mm hubs. However, if you discover a secret to get them to work consistently, PLEASE SHARE!!
Luis
Did you buy the preglued ones? They are notorious for blowing off the rims.
rchippie
rchippie's Avatar
10.19.2008, 12:25 AM
I always scuff the tire with a dremal untill the shine is gone . this will help give you a better bond when you glue them . I have also found that thin glue works the best . I wash new tires with simple green first . Then i do the dremal thing . Then i clean both the tire & rim with brake cleaner . You have to get all the mold release off the tire for a good bond .
REAL MEN RUN BRUSHLESS
