lutach
lutach's Avatar
10.21.2008, 07:54 PM
Originally Posted by ffactory666 View Post
I will have to see if the Enerland 30c will fit the car? I don't have the car yet so i am waiting for guys to give me some measurements of what will fit in it .
Luci i ddin't think you could alter the chassis in the 2s speed scale class ? or is the TC3 for another use.
I am using a 48p 72T spur , couldn't find any smaller in 48p and will start with pinions from 22t - 26t as that's what i have at the moment , should get me going for now .
Well the chassis will be my aftermarket type chassis for the TC3. My TC3 has an after market chassis in it now. Everything else will be stock. If a dragster can be in the spec class, so can my TC3 . As for spur and pinion check this out:
http://www.rcmart.com/catalog/rc-sge...th=293_450_333
http://www.rcmart.com/catalog/rc-pin...th=293_450_345
ffactory666
10.21.2008, 09:00 PM
Your a champ mate , RCMart is next door ( Asia ) and i usually receive products within 5 days from them . Now to go order some spurs and pinions
lutach
lutach's Avatar
10.21.2008, 09:03 PM
Glad I can help a little and I only mean a little, because I have a nice 60T pinion to use with my HV1.5 and the 65T spur .
ffactory666
10.21.2008, 09:12 PM
I am about to put the order through for the spur / pinion and just had a look at there motors . They have the Orion Vortex 2.5t which is $20 dollars cheaper at $79 than the Speed Passions Competition 2.5t . Both rated at 13,800kv , i have not dealt with Speed passion before and don't mind paying more for it if it's a better motor but just haven't heard any reports on the SP motors ?
I'll have to have a look at Brians speed calculator to see what speeds i'm looking at with 13800kv and 65/40 gearing on 2s
lutach
lutach's Avatar
10.21.2008, 09:22 PM
You'll be flying for sure with that gearing .
ffactory666
10.21.2008, 09:34 PM
Why aren't you sleeping man , it's lunch time down under
Ok just used Brians calculator , with above set up it's showing 104mph but the motor will be spinning at 102000 rpm they are only rated to 70000rpm that motor will disintegrate
Now if i use a motor around 9000kv with the same 65/40 gearing the calculator is showing 157mph with the motor at 66000 rpm which is within the limits .
I don't understand how using a lower kv motor will yield more speed , maybe the calculator is not working right .
I put 1/1 in the differential section since the pan car is direct drive and 2.5" for the tires since that's what foams come in un cut ?
lutach
lutach's Avatar
10.21.2008, 10:09 PM
I had my 2.5T screaming for a little while doing some testing on that windy day and the motor is still good.The motor should be able to handle 102,000rpm, but if you're worried, just wait for my motor to come. It should have the rotor wrapped with Kevlar. I'm not sure how Brian's calculator work, but it give a high percent of speed loss with the higher rpm rating.
ffactory666
10.21.2008, 10:43 PM
I think it must have something to do with efficiency loss , not sure .
Think i'll order the Orion in 3.5t which is 9130kv , thats 67562 rpm with 2s and theoretical top speed of 157mph with the 65/40 gearing .
Heck i haven't even driven anything over 60mph ,and even with the 72t spur and 25t pinion i already have , that's 129mph theoretical top speed which one of these pan cars would not handle too well anyway without being modified and niether would the driver
I think i'll be happy with a car that handles and can get over the 85.45mph record in the scale class .
Maybe the above speeds would be nice if attemting the open world record of 161mph but not for me at the moment .
