11.11.2008, 02:07 PM
A nice 2000kv 60-70mm medusa would be fine- 60mm = L can, 70mm = XL can.
Depends how much it weighs really, as an L can motor is alot like the hvmaxx motors- use a higher kv and gear it lower to make the power. The XL cans will provide more grunt from the get-go, but they will also draw more current and heat the esc up more- a balancing act. Try upgrading the firmware on the MM to see if that helps- and adjust the start power and timing etc.
