11.18.2008, 06:07 PM
Originally Posted by himalaya
Good, so who is your reflow soldering QC engineer? You should have a good talk to him.
I inspected two V2s and found A LOT of small solder balls ALL OVER THE PCB BOARD  , some even locate between IC pins  . The solder balls are held in place by either the solder resin or the protective film later applied on the board after soldering.
ROFL, Welcome!
