Originally Posted by hemiblas
I am thinking this is a good motor for the MMM. My 7700 on an MM gets pretty toasty both motor and speed control. I have had to gear down quite a bit on my truck just to get it to work. Now a 3500 on 3S is so much cooler. It will be interesting to see what the application for it will be and what speed controller they recommend.
I will say that most people who have hot escs with the higher kv motors can most likely blame the batteries. No nimh will ever be able to keep up. If I were to run something like this, a polyquest 6000 25c 2s lipo would be the minimum I would use... Od a pair of 3700 2s packs in parallel.
I have a hacker b50 5s motor that I plan to try with 3s lipo. I will use a mm with a fan (due to lack of air movement in the body), and most likely run a ubec and some addl caps...
