Originally Posted by pasan
To go fast of course. A 9000Kv motor on 2S will require tremendous power to propel the TT-01 to high speeds. The stock spur is not 55, and how did you manage to fit in a 25T pinion with the stock motor mount? I remember I was pressed for clearance when fitting a 22T with the 55T spur.
You can get a 55t spur for the tt-01. The same set of mount holes for the 22/58 fit the 25/55, as the spur is smaller in diamter.
I will stick with the hacker b50 5s (7400kv) on 3s lipo to do my session of runs. Getting cooler out here and everything runs faster in cold weather.
