LOSI 5s Hard Case
LOSI 5s Hard Case - 11.21.2008, 08:20 AM
A sign maybe Roar would allow higher voltages...
http://www.losi.com/Products/Feature...rodId=LOSB9834
18.5V 4000mAh 5S 25C LiPo: 1/8 Vehicles
At a Glance
This 18.5V 4000mAh 5-cell 25C Hard Case LiPo battery pack for 1/8-scale vehicles provides the power needed for competitive racing, while increasing running time between charges. The hard case protection keeps the expensive cells from becoming damaged externally. The pre-wired EC5 connector provides a quality connection and excellent power delivery.
Features
LiPo pack's protective hard-shell case provides extra safety
LiPo power provides increased speed and extended run times
Pre-wired EC5 connector provides quality connection and excellent power delivery
NOTE: This LiPo Battery MUST be charged with a LiPo Balance Charger. Losi recommends the Intelligent LiPo Balance Charger (LOSB9605
brushlessboy16
brushlessboy16's Avatar
11.21.2008, 08:43 AM
Yikes, 270 is a bit steep... Getting up there with maxamps...
Anyone else see Losi's batteries becoming the ROAR standard?
I sure hope not, i can almost get 3 zippy 5000mah 5s packs for the same price.
bdebde
That's All Folks!
bdebde's Avatar
11.21.2008, 04:14 PM
Are the zippy's hard case, because that will almost surely be required.
DRIFT_BUGGY
DRIFT_BUGGY's Avatar
11.21.2008, 04:21 PM
Not sure if it has to do with ROAR, this battery is the same size as the 4S Losi Lipo so it can be used in the 8IGHT-E
Losi 8ight
MMM V1 w/1.20
Airtronics MX3 2.4Ghz
TP 5S 5000mah
Neu 2.5D/F
brushlessboy16
The zippies dont but my track accepts softshell lipo's :D
11.21.2008, 07:29 PM
You're lucky, I went to my local track with a rustler to run in an unlimited class (5s lipo, s can feigao, quark 65, and they said no softy lipos...
Patrick
Patrick's Avatar
11.21.2008, 11:26 PM
Does anyone know the dimensions of the losi hard case packs? I haven't been able to find them, losi doesn't seem to give those sort of specs
11.21.2008, 11:49 PM
The specs are:
overpriced X overrated X overmarketed.
brushlessboy16
11.21.2008, 11:55 PM
The specs are:
Woah- those are the same ratings as the ones found here- Clicky
DRIFT_BUGGY
11.22.2008, 12:00 AM
1.8 x 1.9 x 6.3in
Losi 8ight
MMM V1 w/1.20
TP 5S 5000mah
Neu 2.5D/F
