11.22.2008, 01:39 PM
Originally Posted by superlightmaxx View Post
lincpimp, since you seem to be a master at brushless motors around here! (I read a lot of you posts...)
I have a question for you:
do you think I would be better off with 2 7s feigao instead of 2 8s? I really dont plan to go to 3s lipo! I have all 2s lipo so i'm trying to find the best feigao motor that would run good on 2s without any heating issues! I could even gear it in first so geraing isn't an issue! and my e-maxx is going to be under 9 pounds with lipos and everything on board...
I dont want to attain warp speed but I like to pass 40mph
I have owned quite a few brushless motors, and my first was a 7s feigao. I ran it on 9 nimh 3800 with a MM in a rustler. I could easily melt the solder on the barrey bars with that setup, the 7s is a powerful motor, and requires a good lipo, what do you plan on using?
The 7s should be fine. You truck will be light and if your gearing is not high they should not get too hot. On 2s those motors will spin max of 37k rpm, which should be fine.
I once ran an emaxx with one 7s motor on 3s lipo. It was geared 22/54 and would thermal the MM in 2nd gear! It was geared for 80mph in 2nd and it did pull over 100 amps as it puffed the lipo I was using (crapamps best).
Those motors can pull some amps, but since you will run 2s and a pair of motors it will spread the load. The sidewinder is good for about 80 amps so you should be fine.
