JThiessen
JThiessen's Avatar
11.23.2008, 02:16 PM
The reason for twisting center shafts is because it takes the largest amount of the torque. The grub screw has nothing to do with that. On yours, you should try replacing the end of the shaft, or put some loctite on it.
