Originally Posted by suicideneil
Interesting dilema.
Since the vxl motors are something like M can, and 2 of those can achieve 60mph on 2x 3s lipo @ 3500kv, then a pair of S cans on 2x2s each should do 40mph easily enough @ 4400kv. Like you said, a single L can is enough power for you, so a pair of S cans should be about equal in that respect- just added cool factor from the twin BL layout.
If you wanted to go for higher speeds, L cans would be better ofcourse...
The vxl motors have shorter windings and magnets than a s can feigao, so I would call them petite motors...
Originally Posted by BL_RV0
Personally I'd go with 2 s cans.
For his setup of 2s lipo the higher kv would be better. And gearing options are limited to 22t max on the pinion before you have to buy more expensive pinions. I would personally use 2 sidewinders and the cc 5700 motors. Especially the new design of the motors. Or a pair of 50mm medusa v2 motors.
Originally Posted by traxxasbasher13
I still say L cans.
Not going to get enough motor speed out of L cans, and the gearing will be difficult to achieve with only 2s on each motor.
