Unsullied_Spy
Unsullied_Spy's Avatar
11.25.2008, 01:19 AM
2650: Buggy
2200: Truggy
The 2650 will be fine on 4s, I'd start with a 13T pinion. 6s will be fine as long as you don't hold full throttle for too long. Do NOT free-rev the motor, go downhill at speed, etc. and you will be fine. Considering the voltage drop with the load on the lipos, and the fact you probably won't hit full motor RPMs when used in your Buggy/Truggy you should be fine.
