david lamontagn
10.27.2008, 08:31 AM
Originally Posted by Unsullied_Spy View Post
I plan on putting 30 series Torque wheels with Badlands on my future CRT once Mike gets his new Chassis in stock. They're 5" so it'll give another 1/2" of ground clearance, just gotta gear down a little to handle the larger tires. I use these wheels/tires on my Rustler and they are the best!
Gear down is not the problem, the main problem will be the hub, knuckle and bearing tohandle this side load cause by the largest tires.
Unsullied_Spy
Unsullied_Spy's Avatar
10.27.2008, 11:30 PM
Is it that big of a deal on the CRT? I run them on a Traxxas Rustler and it seems to be holding up to them pretty well. It would be nice if Mike would make a kit that uses 8mm axles and an aluminum knuckle with big bearings and came with 17mm hexes--that would be a popular kit I'm betting.
david lamontagn
10.27.2008, 11:51 PM
+1 and i would be the first to order it
Unsullied_Spy
10.28.2008, 12:07 AM
Funny, I just thought it up at work today I should PM him about it and see if he could do it...
yappa
10.28.2008, 12:21 PM
david lamontagn
10.28.2008, 10:42 PM
What's this adapters yappa??????????????
Metallover
RC-Monster Spudgunner
Metallover's Avatar
11.25.2008, 11:30 PM
Hey those look like the adapters you can get at the RCuniverse marketplace. I think they are way overprice btw.
Since this is a tire thread, what would be a good tire to run on and offroad? It will be completely for bashing. Also, is it really worth moving up on the tire size?
rschoi_75
Certified Spaceball
rschoi_75's Avatar
11.26.2008, 01:22 AM
Riley, give some gladiators a try. I'm using those right now and I think they are great for all around running. The M3 compound is the one you want.
rcm xt8
rcm xb8
rcm crt.5
hoovhartid
Monster Bottle Opener
hoovhartid's Avatar
11.26.2008, 03:06 AM
the m3 is the softer one...why would you want that over the harder one?
wont they wear out quicker?
<a href=http://i87.photobucket.com/albums/k137/darrajsam/bottomline.jpg target=_blank>http://i87.photobucket.com/albums/k1...bottomline.jpg</a>
I used a "bottom" line.
rschoi_75
Certified Spaceball
rschoi_75's Avatar
11.26.2008, 04:33 AM
oops, yeah... my bad...I just rechecked the proline website. You're right. The M2 compound is what I should have suggested. Its the harder compound.
rcm xt8
rcm xb8
rcm crt.5
Metallover
Metallover's Avatar
11.26.2008, 12:12 PM
Ok, so M2 Gladiators. Do they fit on a 2.2 truck or buggy wheel?
rschoi_75
Certified Spaceball
rschoi_75's Avatar
11.26.2008, 12:29 PM
2.2 truck wheels.
rcm xt8
rcm xb8
rcm crt.5
hoovhartid
hoovhartid's Avatar
11.26.2008, 01:24 PM
LOL its all good. I had them in the cart and waited for your reply...
....i thought maybe the harder compound caused slipping or something I had not thought of.
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
01.02.2009, 04:36 PM
Just took the CRT.5 out for a dash in the snow. The slash tires suck in snow! I wasn't out driving in deep snow, hardpacked snow in my apt parking lot. I don't think I even managed 1/2 the speed of what it's geared for. Topping off the battery and I'm going to try the bowties in he snow. I know it won't go as fast cause they are the stock size bowties, but there should be a lot less spinning and some more turning control. I HOPE!!!
01.02.2009, 04:40 PM
Try some 2.2 badlands...
