NEU Motors
Marvin
THE Paranoid Android
Marvin's Avatar
NEU Motors - 11.26.2008, 12:34 PM
Hi there!
What size screws (thread size & length) are needed to mount NEU motors to Mike's motor mounts?
Thanks
Simon
11.26.2008, 01:09 PM
Use 3x10mm cap head machine screws, m3 thread.
Marvin
Marvin's Avatar
11.26.2008, 01:29 PM
Thanks
Serum
Serum's Avatar
11.26.2008, 01:51 PM
Just make sure the threads don't hit the copper windings; the Neu motors have got their windings sitting rather deep from the front; you can easily check with a tooth-pick how deep the holes are.
11.26.2008, 01:52 PM
Yeah, I wouldn't run a screw longer than 10mm, as a rule of thumb.
Marvin
Marvin's Avatar
11.27.2008, 12:23 PM
Cheers guys, it's good they aren't imperial (cos that would be a pain - I've only got metric tools)
DRIFT_BUGGY
DRIFT_BUGGY's Avatar
11.27.2008, 04:28 PM
Do many people use the RCM Front Motor Cover - http://www.rc-monster.com/proddetail...rontmotorcover
Losi 8ight
MMM V1 w/1.20
Airtronics MX3 2.4Ghz
TP 5S 5000mah
Neu 2.5D/F
jnev
jnev's Avatar
11.27.2008, 05:08 PM
I use it on all three of my Neu motors.
DRIFT_BUGGY
11.27.2008, 06:39 PM
Are those 4 little holes for other motors than Neu? Do you screw it to the neu motor and then put it on the motor mount or just place the two together and only use 2 screws which hold all 3 together?
Losi 8ight
MMM V1 w/1.20
TP 5S 5000mah
Neu 2.5D/F
11.27.2008, 07:12 PM
They work for lehner motors as well, so that mounting holes are deeper. Lehners are very shallow.
11.27.2008, 09:12 PM
I believe you screw the cover to the cover to the motor (with counter sunk screws, then the other 2 holes are for mounting it & motor to the motor mount. I believe...
