Metallover
RC-Monster Spudgunner
Metallover's Avatar
11.28.2008, 07:34 PM
Dont burn your hand with that motor! Or the Chassis!
I would keep a VERY close eye on the electronics when you are doing speed runs. It will draw a ton of amps and your electronics will run red hot. I'm also worried about your lipo. the mamba motor will probably work for speed runs, but the vendetta is a heavy car. That is the reason most people use 28mm/400 sized motors like the ammo and Neu. Make sure to have adequate cooling. If you are using the 1/10th sidewinder, the esc will probably be ok.
