SeanZ0r
12.07.2008, 01:09 AM
PCB looks like it's still in good condition, I would desolder all 3, cut wire, and restrip all 3 the same and solder it again. Easy way to solder in this situation is. strip the wire, twist the wire straight, tin that wire with solder. Then heat up the bottom of the pcb and slide the wire through the hole, But don't apply too much heat or else you could burn up the pcb or desolder adjacent solder points. Use fine tip and lo-heat!
