Im looking for a decent, all around charger, this one will do more than i'll ever need, because my E-Revo some day will be 6s, so its perfect. Is it a decent charger, and what power supply would i need to get?
That charger will work fine . But it will take a while to charge because of the low wattage . this charger will charge your lipo faster . It's what me & alot of of other members use .
Thats a really nice charger, but i only have 150, maybe i'll save and get that one.
I understand but it's only a few bucks more & you will never have to buy another charger . It will be able to charge your 6s lipo at a much higher amp rate than the other charger . Ask for other members opinion on which charger is better .
I'm certain that you won't be happy with the 0606i, it's a good charger and all but not for a dual battery setup such as the e-revo. You said that someday you'll run 6s so I'm going to assume for now your running 4s. The 0606i will charge a 2s pack at up to 6amps so 2 hours to charge 2 seperate 2s 6000mah packs. If you where to go to 6s (2x3s) 5000mah is the biggest pack that will fit. That same charger will only charge a 3s pack at about 3amps so it would take about an hour and 40 minutes per pack! I know this because I started with the eos 0606i ac/dc charger. I now run a eos 0610i duo with an 18 amp Ofna power supply. It will charge 2 3s packs at 1C without a problem! The charger is costly but it should meet your charging needs forever!
Single 4s pack then I'm guessing. Means the most the charger will charge at is 3 Amps so if you have a 5000mah pack your looking at about 1:45 to charge the pack, 6000mah will likely take about 2:10
The Accucell-6 is a nifty little charger - I've been using one for about a month and it is a very featured charger, will pretty much do everything. Its limitation is that it's only a 50watt charger. Within that limit though, its hard to beat, especially given the price.
no means to thread jack here so will someone pm the answer to me?? ok, so my Q is will this 50w charger can supply the power to charge 2x 3s1p (6s) 5000mah at 5amps?? how many amps should i look to get?? thanks all!!!
