Problem programming 9920
Jasper
Problem programming 9920 - 11.20.2005, 06:15 AM
Hello,
I finally got my savage build up and got the warrior 9920 with the 7XL motor.
I'm trying to program it but I can't do it so far. I tried the way of Mike, the way of the instruction guide from BK, but that doesn't work. I only hear one beeb and when I hit full throttle, I don't hear anything anymore.
But it does work when i
1. connect the motor wires
2. plug in the wire from the warrior in the receiver.
3. plug in the drive cells
4. Put on the transmitter
Then I hear one BEEP, then I hit full throttle, and then I hear two BEEPS. I thought that the controller is then programmed succesfully. But when I put on the red jumper en connect all the wires. The motor is driving full throttle backwards. And then I can't get the red jumper off the esc because I think this isn't right.
Can someone helpe me pleaseeeee
I WANT TO DRIVE THIS BEAST!!!
Serum
Serum's Avatar
11.20.2005, 06:20 AM
what does it do? does it drive full throttle backwards when you connect the batts?
MetalMan
MetalMan's Avatar
11.20.2005, 11:43 AM
On your transmitter, try reversing the throttle channel (channel 2). If the Warrior 9920 can't recognize full throttle, and sees reverse instead, it can get all messed up.
Serum
Serum's Avatar
11.20.2005, 12:58 PM
It is solved, i helped him thru MSN...
coolhandcountry
coolhandcountry's Avatar
11.20.2005, 03:31 PM
way to go serum. :D What was the problem?
Peace!
Country
Help support the
Rc-Monster
Buy here
Serum
Serum's Avatar
11.20.2005, 03:50 PM
Several..
plugged in channel 1 for a while (as a test) and forget to plug it into 2nd channel, we enlarged the EPA, and he needed to put it in reverse as well. weird thing, that he could programm it the first time though..
nbcaznmaster
RC-Monster Cult Member
nbcaznmaster's Avatar
11.20.2005, 07:16 PM
good job seruM!
~~~~~~~~RC Garage~~~~~~~~
LSP-R - Picco .26
Custom E-Revo - Warrior 9920/Feigao 9L
Nitro Revo - .18tm
  Send a message via AIM to nbcaznmaster
