JThiessen
JThiessen's Avatar
12.16.2008, 09:42 AM
1. which motor. Neu 1515 1Y or...2.5D
2. which batteries. Neu 5S or Mikes 5S
3. should i upgrade to spektrums new dx3s. I would, you will eventually.
4. what gear setup should i be using? pinon, spur, whatever. Use BrianG's speed calculator to get the rpm's up around 40K+
5. anything other info, tips, things i should get. buy the parts now to upgrade your diff cases/cups to aluminum - you will need them sometime in the near future,
Have you run a Revo in stock config before? If so, give us a report on those Integy shocks. Aw Hell, give us a report anyway..!
