George16
Supermaxx
George16's Avatar
12.16.2008, 09:14 PM
Gee, thanks. I actually looked at your's and Rootar's (your's was converted ST-R) builds to help me complete mine. I thought about the lexan but I'm too lazy to do the cutting. I'm might do it once I go to the ship since we have nice machines(CNC and what not) that I can use. The conversion was easy and painless to say the least.
One thing I noticed about the Kyosho is the amount of chassis flex compared to other truggies like the GS SUT Shaun sent to me. To me, there is a lot. I'm going to order King headz chassis braces shortly. Let me know what you think about it.
The overall length of the servo tray is 130mm.
I'll be running a 5S setup using Neu 5AH lipos. Right now, it's geared for 46 using the stock 50T metal spur and 15T RCM pinion. I tried installing the plastic 46T spur with 13T pinion but the mesh is not right. Depending on what I'll find out when I do my initial run, I also have a 48T spur and 14T pinion as spares.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
