I used 90wt diff fluid (which was the thickest that I had on hand). I am going to try the diff and then try the center spool. I just wish somebody made a heavy duty center slipper to go with that solid shaft....
Are you sure you used the right oil??? That there is shock oil, no good for diffs!!
