12.24.2008, 08:10 PM
That will not work because the rear disc is your problem- not the front which is what that cover will fix.
12.24.2008, 08:11 PM
Nevermind I am an idiot.
Ryu James
Ryu James's Avatar
12.24.2008, 10:53 PM
no, you are right. if the spacer is even almost the same size as the motor can, which it looks like it is, it still wont work because then the spacer will just hit the brake disc.
Jammin SCRT10 Neu 1512 1y
jayjay283
jayjay283's Avatar
12.24.2008, 11:16 PM
Thats not what the brake spacer Mike makes looks like, I have one, its like a 3/4 moon cut out to miss the brake. its not the full spacer in the pic
slimthelineman
slimthelineman's Avatar
12.24.2008, 11:24 PM
this is the one. i drilled and pressed in two bearings when i was using it. using the motor brakes now.
Ryu James
Ryu James's Avatar
12.24.2008, 11:44 PM
yeah, something like that would be perfect. where can i buy that?
