Thread Tools Rating: Thread Rating: 11 votes, 5.00 average. Display Modes
12.27.2008, 01:12 AM
That is one fantastic looking truck!
Hmmm.........no slipper?
You said you got the motor mount from tdr? Where's that at?
Heres the site: http://tdracingrc.com/
The lst has a very different slipper, much like a dry basket style clutch on a bike. It has quite a few disks and pads, the pads are round with teeth that engage the basket that is keyed to the input shaft, and the disks look like steel brake disks that have a hex punched in the center, a hex shaped collar slides over those disks which are staggered in between the pads and the spur is attached to that hex collar. A sping that rides on a thrust bearing keeps pressure on the assy. This slipper can take some abuse, I had it 1 full turn loose and it was barking like crazy, but did not heat up much. I did a few full throttle runs on the blacktop too, then tightened it down and no issues.
