Questions.
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
Questions. - 12.30.2008, 08:19 PM
Hye there. It sounds like you have answers to most of your questions for the most part. Nice setup and congradulations on your success with the operation of your build. One added note on teh gear cover on your tranny. I used longer screws and placed nylock nuts on the screws first, which makes a small gap between the cover and the mounting plate. That took care of the rubbing issues for me, protects the gears from grabing any wires, and also gives you a little cooling effect for the gears during heavy useage. It works great and it is easy to install and remove just like normal. Good luck with continued success with your project.
