mohanjude
Need for speed
mohanjude's Avatar
01.02.2009, 02:41 PM
Motor may have demagged... There is a method of testing the phases against the can to check for shorts, and there must be some sort of resistance spec. If two of the phases are shorted it would act as a brake on the motor, and would also cause some massive current draw thru the esc. I would investigate the motor further. Did you buy it new, or used? Any physical damage?
I bought the motor off a german seller it looked practically new. If the motor is demagged will it run full throttle on the bench? On the bench the motor draws about 14 amps at full throttle on 39V with no load. The motor heats up slightly but no other issues identified.
