V3 X2 CRT conversion ???'s
sweetride4me
V3 X2 CRT conversion ???'s - 01.03.2009, 03:59 PM
Will this work with and X1 CRT??? Just curious... as it would take time and make things easier....
teknorc
01.03.2009, 08:38 PM
As long as you have the new center diff and the front and rear truggy diff ratios, it should work fine.
Tekno RC - Performance Parts
sweetride4me
01.03.2009, 10:42 PM
What do you mean by front and rear truggy diff ratios???
George16
Supermaxx
George16's Avatar
01.03.2009, 10:51 PM
Chris, truggy uses 43/10 diffs while buggies use 43/13. You need to open up your diffs and count the pinion teeth.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
01.03.2009, 10:54 PM
The difference in the pinion teeth is for the different size tires. Basically, it changes the gear ratio for each application.
sweetride4me
01.03.2009, 11:29 PM
Well isn't my X1 crt a truggy..... so it should be all set right??? Will it matter I'm using the X1 center diff with the 62 tooth spur???
skellyo
skellyo's Avatar
01.03.2009, 11:44 PM
The X1 CRT actually has 13:43 diffs, not 10:43. That's why the stock spur is a 62T versus something smaller.
sweetride4me
01.03.2009, 11:54 PM
So that shouldn't matter then right??? since it's geared accordingly..... also if I buy the kit which version do I buy the 36mm or 44mm I'll be running the castle 2200kv monster combo...
thanks for all the help everyone
George16
Supermaxx
George16's Avatar
01.03.2009, 11:55 PM
Unfortunately, your truggy has a 43/13 diff:
From the parts listing on page 29:
40516 STEEL SMALL BEVEL GEAR 13T 14.95
40517 STEEL BEVEL GEAR 43T 38.95
Link for the manual:
http://www.ofna.com/pdf/34963-x1crt-pro.pdf
Edit- skellyo beat me to it.
You'll eed the 44mm. And yes, you can gear it accordingly.
Revo with OS .18TZ
