I'm using the MMM so 6s in an option, but in the name of keeping the weight down I would prefer 4s. My trans is a Gmaxx single speed with steel idlers and the other gear is aluminum.
with the heavier weight it would be a good idea to go with 6s to keep the amps lower, go with a motor kv in the 1500-1700 range and gear for 40 mph and you will have a happy running system
