Castle Link Vista 32 bit vs 64 bit compatibility
Thomas Porfert
Thomas Porfert's Avatar
Post Castle Link Vista 32 bit vs 64 bit compatibility - 01.13.2009, 11:43 AM
Just to reiterate and summarize what has already been said on this thread:
Installation on 32 and 64 bit: Save the install file from the website to your computer's hard drive. Find the icon located on your hard drive, it should be called "CastleLinkInstall3.XX". Right click on the icon and choose "Run as administrator" and it should install just fine.
Vista 32 bit compatibility: Works with Castle Link and Mamba Max. Meaning it works on every product that we offer that is Castle Link compatible, including the Mamba Max.
Vista 64 bit compatibility: Works with the Castle link but NOT the Mamba Max. Unfortunately we have been unable to find a solution for getting the Mamba Max driver to work on 64 bit. But products like the Monster, Sidewinder, 1/18th controllers, BEC etc. will work just fine; the Mamba Max is only controller that will not work with 64 bit.
Hope that helps clear up the waters a bit. If you have any questions or problems with Castle Link installation on Vista, please give us a call in Tech Support, we'll be happy to help.
Thomas Porfert
Castle Tech Support
