Info???
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
Info??? - 01.21.2009, 10:53 PM
How about a little detail here. What exactly are you talking about? If I was to assume that you are talking about the E-Maxx tranny, which one the 3905 or 3906? I have the 3906 (old) E-Maxx setups. I have several different versions of steel idler gears in them. I have UE idlers in one, RCM steel idlers in another, and TRX steel idlers in the other ones. All of them work just fine. I also have aluminum 1st & 2nd gearing in all of them as well for better wear and tear and all are in aluminum tranny cases. I use blue Aqua "Speed Grease" in each of them to keep the wear down even more, and it really makes things run smoother and quieter. Life has never been so good. If you are not talking about the E-Maxx trannys, then disreguard all of this.
