I am using:
-Mamba Monster Max ESC
-Airtronics MX-3 FHSS
-Feigao 9XL
-Zippy 4s1p 5000mah lipo
[U]
My problem:
The system is what I just got. When I received it, I tried to bind the transmitter to the receiver, all went well as I went through the normal procedures, the led stayed solid, the esc makes the proper double "beeps" and when I drive the car more than 8-10 ft. away from me, the fail-safe kicks in and I have no control over the car anymore.
Another issue I am having is that my motor does not have any movement after I program the ESC using the castle link. However, if I return all the settings to default, the car will work, but I have the same problem as I stated above...
*I really do not know if this is a receiver or ESC problem. I hope that anyone before that may have experienced or even heard of such problems can share their helpful insight with me...
thank you for your time and consideration!
