Matthew_Armeni
Matthew_Armeni's Avatar
02.05.2009, 05:25 PM
It may have something to with the ESC you're using. It's an airplane ESC, so it has a soft start, which may be causing the clutch to slip excessively during takeoff. I tried an airplane ESC and there was just too much lag for my taste, even slower than a high value punch control setting on the Mamba's. Also, just in case no one has mentioned it, be sure the shoes are in the leading edge position, not trailing like you would have them in nitro.
  Send a message via AIM to Matthew_Armeni
