rootar
rootar's Avatar
02.07.2009, 10:37 PM
i dunno if you ran it yet or not but you might want to drop atleast couple teeth on your pinion when you bump up to 5s especially since you went to a small spur....or youll be geard to the moon.
plettenbergs
plettenbergs's Avatar
02.07.2009, 10:50 PM
i tried to run today!...i am using my new Hyperion charger for the first time and did not charge the batts properly...i balanced but did not charge after...my bantam charger abances and charges at the same time...the 0610i balances then you have to charge after!!
also cant run 5s until i remove the TRAXASSS bat comectors from the MMM esc!...i will just run the 4s with the 17/46 and keep a close eye on temps!
i will let you guys know how it goes!!
