02.08.2009, 02:33 AM
You are probably referring to using a resistor? Patrick from CC specifically said not to do this with the MM or MMM. Something about the arming sequence being different than an aircraft ESC and could cause damage to the logic circuits.
shaunjohnson
i pwn nitro
shaunjohnson's Avatar
02.08.2009, 02:57 AM
so just put up with it and replace the deans plugs every 6 months??
  Send a message via MSN to shaunjohnson
sleebus.jones
I like chocolate milk
sleebus.jones's Avatar
02.08.2009, 12:12 PM
It's sure a lot better than replacing the ESC on a more frequent basis.
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
02.09.2009, 09:03 PM
I know what he's saying. After repeated sparks, the contacts can get pitted and charred, which obviously increases contact resistance.
Only the tips of Deans get pitted, etc. The contacts are on the side, so I don't see why they would have to be replace so often. The same for bullet connectors.....
MetalMan
MetalMan's Avatar
02.08.2009, 03:32 AM
He says not to do it with any CC ESCs
02.08.2009, 03:36 AM
I though he said just not with the MM/MMM/sidewinders. Hmm. I used a no-spark circuit with my HV110 and it worked fine while I was using it.
