doo540
02.17.2009, 08:47 PM
mistercrash I just checked your photos of the lst in the revo bulks, I didn't take that much material out of the side walls on mine, they are thin near the pinion, but the area buy the ring gears is still mostly there. I also ground the rear boss of the lst diffs as much as I dared to reduce the amount of clearance on the rear of the bulk. I will try to get some pics up later.
