squeeforever
squeeforever's Avatar
02.24.2009, 12:46 AM
Pmed
The narrow beadlocks will not work very well with the moab 40s, as they are quite wide. The moab xls are much taller and narrower.
Too much offset on the cheyennes in what direction? I want the track to be wider than the commandos can offer...
Ah...I gotcha. You want more offset then, not less. Then the Cheyennes might be enough for you, of course they have the usual 1/2" as do most 40 series, including the Commandos. It looks like it has less offset on the Commandos for some reason, but its the same as a offset Velocity or the Cheyennes. 1/2" offset is quite a bit.
