water cooler for finned motor?
bustitup
water cooler for finned motor? - 03.02.2009, 03:51 PM
yes its for a boat
anyone got any ideas on how to build a water cooler system for a neu castle 2200kv motor
I'm thinking of just making a coil around motor with aluminum tubing...would copper be better?...easier to bend
be pretty nice if you could devise some way of making a slightly bigger can to fit around the fins and sealing the ends with o-rings and sealant like on the smooth can coolers where the water actually flows over the motor
03.02.2009, 04:48 PM
Coils wont work at all well with a finned motor, very little contact area.
if you could find a metal/ plastic sleave just slightly larger than the motor diameter, and seal it like you said (or with silicon/jbweld etc), it would be easy to install the nipple inlets and then run the tubing where it needs to go.
johnrobholmes
johnrobholmes's Avatar
03.02.2009, 04:51 PM
Find copper small enough to fit in between the fins, and you could make a very effective one.
---JRH---
03.02.2009, 05:05 PM
That occured to me too, but the tubing would need to be ~3mm OD at most by the looks of the motor, never seen anything that small very often. Copper would be best though yeah, better conductor or heat so far as I know compared to aluminium.
azjc
03.02.2009, 07:09 PM
how big of a boat?
03.02.2009, 07:52 PM
Find a lathe...
Bad Karma
03.02.2009, 08:32 PM
Or send to NEU pay some $ and ask for a smooth can...
bustitup
03.02.2009, 09:43 PM
Originally Posted by azjc View Post
how big of a boat?
Its a 29" Catermaran mean machine
Andrew32
03.02.2009, 10:04 PM
Personally id go with the tube idea.
1. Id Lathe out a tube of copper or aluminum to fit snug on the fins
2. Lathe and weld some bungs for the water inlet
3. Grind the fins right over the bung about 1/4" so the water flows around the motor
4. Seal with some silicon or anything similar.
PBO
RC-Unobtainium
PBO's Avatar
03.03.2009, 02:20 AM
Originally Posted by bustitup View Post
yes its for a boat
Try this from www.fastelectrics.com
edit: I posted without reading your last paragraph & I now assume you have a finned can? They do a larger one that may fit over fins although I doubt it would be effective even if it did
bustitup
03.04.2009, 11:59 PM
why?...same principle
PBO
RC-Unobtainium
PBO's Avatar
03.05.2009, 01:11 AM
The fins on the can prevent full contact with the cooling jacket & trap hot air inbetween the fins which then expands, pushing the cooling jacket further away...etc
