Takedown
WARNING: May become violent.
Takedown's Avatar
01.13.2009, 05:29 PM
I had the same issue with 2 of my MM's awhile back. Solved it by disabling the on/off switch all together and bought my first set of TRX plugs to replace the deans. I am very happy in doing so. They have more contact area, more confortable, more grip, no heatshrink...
RIP- Tammy (9/14/08)
Krawlin
Got brushless?
Krawlin's Avatar
01.13.2009, 07:36 PM
I suggest you sell the MM while it is still alive and invest in a MMM- you won't regret it.
Nah, I want to see if I can get this thing to work. Not just going to take the easy way out this time.
it is your connectors, i told you that already, silly
Yeah, yeah..... I just hope the new connectors fix the problem so it wont happen again for however long the MM is around before it gets fried from by my motor.
How did you completely disable the on/off switch? Just solder the wires together like I did?
Monster GT Conversion
traxxasbasher13
01.13.2009, 07:43 PM
I think he might have made the wires super short then soldered them together.
01.13.2009, 07:45 PM
^^^yeah, you can solder the wires together like you did, or put enough solder on the board to jump the gap between the two wires solder points. Either will "permanently disable" your on/off switch.
Takedown
Takedown's Avatar
01.13.2009, 08:57 PM
I unsoldered the switch and wires from the board and jumped the two joints on the board together with a small peice of solder. Was very easy to do.
Krawlin
Got brushless?
Krawlin's Avatar
01.15.2009, 08:29 AM
Should be getting my EC5's in today! I will get some pics when they are all soldered up.
traxxasbasher13
01.15.2009, 11:04 AM
Cool I want to see them.
Krawlin
Got brushless?
Krawlin's Avatar
01.18.2009, 12:08 PM
Haven't gotten the new connectors soldered up yet, the Maxx build is sort of on hold for now while I work on my truggy.
Krawlin
Got brushless?
Krawlin's Avatar
02.13.2009, 08:14 PM
Well I got the connectors (EC5's) soldered up, ran the Maxx, and it worked for about 2 minutes, then pulled its off and on crap again, then the motor destroyed my spur gear....
So a couple hours ago, I ordered the MMM.
Took some pics of the Maxx, edited them in photobucket, turned them into teaser shots -
(Edited the pics so they dont encourage more comments like 'Neils... )
02.13.2009, 08:23 PM
Hmm, hopefully it wont make too much mess when it does...
Krawlin
Got brushless?
Krawlin's Avatar
02.13.2009, 08:30 PM
I had a feeling someone would say something like that...
Oday9513
03.02.2009, 10:22 AM
cool build, you have a very nice maxx Chris. I wanna see it run with the mmm
AP Alex
AP Alex's Avatar
03.03.2009, 09:30 PM
Here's pics of my 17 lb. E-maxx. It is a brute.
http://i656.photobucket.com/albums/u...s/IMG_0772.jpg
http://i656.photobucket.com/albums/u...s/IMG_0773.jpg
http://i656.photobucket.com/albums/u...s/IMG_0774.jpg
http://i656.photobucket.com/albums/u...s/IMG_0775.jpg
What do you think?
traxxasbasher13
03.03.2009, 11:54 PM
That thing is sweet, but really 17lbs, thats kinda ridiculous. How much does that cage thing weigh alone?
AP Alex
AP Alex's Avatar
03.04.2009, 09:12 AM
The way I weighted it probably was not real accurate, but it was the only way I could weight it. I weighed then I weighed holding the truck. The cage is not heavy, but i just think it is the combination of all the aluminum parts including the rims and tires.
Tags
kick ass maxx
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
