X-Brace Motor Mount Flex?
MadDog
X-Brace Motor Mount Flex? - 03.05.2005, 09:41 PM
A guy at the LHS today pointed something out today. The X-Brace motor mount seems to have a lot of fex in it. Is there anything out there that helps this? Maybe some kind of rear brace or something?
E-Maxx with Feigao 540 9L, Warrior 9918, FLN Chassis Kit, and Gorilla Chassis.
 Send a message via ICQ to MadDog Send a message via Yahoo to MadDog Send a message via AIM to MadDog
RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
03.05.2005, 10:13 PM
The flex doesn't seem to bother it when the motors are mounted low to the side. I have seen some users mount the single brushless motor in the center top position and always was concerned with the motor flexing away from the spur gear and stripping it. The motor mount can be braced with turnbuckles if it becomes an issue.
MadDog
03.06.2005, 12:08 AM
I have my motor directly on the top.
What do you mean by using turnbuckles?? how does that work (any images?)?
RC-Monster Mike
Site Owner
03.06.2005, 11:10 AM
I am currently unable to upload pictures from my camera, but I will try to explain.
If you take a rod end (shock or turnbuckle) and attach it to the motor mount with a screw (screw through the motor mount into the turnbuckle), then repeat this with another one in the rear shock tower. Now, you will have two rod ends that can be easily connected with a turnbuckle (screw through fixed rod end into turnbuckle rod end on either side).
gorillamaxx
gorillamaxx's Avatar
03.06.2005, 02:20 PM
The mount was originally designed to lower the cg of the motors. I still think the best set-up (even for a single) is as low as you can. The center will work, but in this location, you're putting all the weight furthest from the support points.
Good jod on explaining the rod idea Mike :L:
I know we have a few guys on this site that are running large single motors on center - it would be good to get their input here.
Thanks
rc4x4nut
I have experimented with every position on the motor mount and havent seen any flex at all with my heavy HVMaxx motor (twice the weight of a normal motors)
Qball76
03.13.2005, 12:52 PM
Thanks
I've been running the Novak HV in the on center position up top and the result has been partially stripped spur gears. I've got a 9L on the way and I plan on lowering it down with the controller on the opposite side. At first I assumed that by putting the motor on center I would get better balance, but I don't think you gain enough to make it worth the headache of stripping spur gears on hard landings.
Superemaxx89
03.13.2005, 03:57 PM
i just noticed you can run a triple BL with this motor mount!
rc4x4nut
03.13.2005, 04:01 PM
Yeah but imagine how much stress and flex is going to be on the motor mount. Although it would be cool to see it done:D
RC-Monster Mike
Site Owner
03.13.2005, 07:55 PM
Get yourself checked out, supermaxx. You are clearly INSANE to even consider a tri-brushless set-up!
Qball76
03.13.2005, 08:41 PM
Sounds like a challenge Supermaxx!!!
Superemaxx89
03.13.2005, 11:28 PM
i wouldn't know where to put 96 NIMH cells on a gmaxx chassis:p
Rcbros
Rcbros's Avatar
03.15.2005, 10:46 PM
So are we saying to put it on one side or the other? Would this upset the balance of the truck?
  Send a message via Yahoo to Rcbros Send a message via AIM to Rcbros
RC-Monster Mike
Site Owner
03.15.2005, 11:23 PM
This is saying a motor on each side AND on in the middle top position on th g-maxx motor mount - three motors!
Rcbros
Rcbros's Avatar
03.16.2005, 12:58 AM
No for one motor where should it be mounted. If its mounted on one side wouldn't the balance be messed up?
