B4maz
03.17.2009, 11:02 AM
Originally Posted by rcjmaxx View Post
B4MAZ,where'd you get a pinion that BIG? Is it custom built? I've been looking for some larger than 25t, which is the largest mike sells.
You can get them from https://sdp-si.com/eStore/. Use the menu on the left to look under spur gears. Then narrow down what options you need for your gear.
