pb4ugo
03.24.2009, 04:29 PM
Got a bit more done. I forgot to show the bottom of the motor plate. It has holes for all xl size motors, Medusa 80mm, and Tekno Neu square can. Easy enough to make adapters for any other motor. My Hacker isn't feeling too good, so I may need to scrounge enough money to test these other mounting points soon.
Here's an undershot with the skid plate:
Here are a few showing the transmission separately and then installed. The whole thing will pull out after removing four screws (after removing the motor which consists of two screws) and from there the end pieces pull off so the whole thing will pull apart. Now it's easier to see how the motor plate will adjust from a bird's eye view.
All I need now is a rear dog bone, the roll bar pieces to get cut at my water-jet shop, and a body.
